Puch Maxi N mit Druckluft
hab da was im internet gefunden, dass ich euch zeugen möchte.
Keine revolution, aber zumindest mal was anderes.
:arrow: Übersetzung Googeln könnt ihr selber, sofern nötig und es euch interessiert.
:arrow: NEIN es ist kein NOS und KEIN Lachgas :wink:
This Puch moped only has a range of about 7 miles and with a top speed of only 18 mph, it isn't going to break any land speed records, but there is definitely something special about it: it runs on air. Jim Stansfield, an aeronautics graduate outfitted his Puch with a pair of carbon-fiber air cylinders, two rotary air engines and the rest, as they say, is history.
The air powered Puch is a very interesting concept and while the seven-mile range might not sound like much, it is plenty for getting around city centers. Add to that the convenience that it takes only a couple of seconds to refill the air from a larger cylinder and you have something that could just work.
The only drawback to this system as I see it is that it is running on clean air; of the sort that is generally found in diving cylinders. If you have your own bottles, that is going to cost you $5 or $6 per big bottle and could push the running cost up a little over an electric bike. On the other hand, there is no need to run the system on dive-grade air. If you are not going to use the cylinders for breathing then there is no reason why you couldn't fill it yourself with standard compressor air.
Quelle:
http://randomdigest.com/2008/04/16/
(Fast ganz unten)
Ronin
Re: Puch Maxi N mit Druckluft
Beitrag von Ronin »
Geil^^ Was würde die Polizei wohl sagen, wenn man mit sonem Ding aufkreuzt?
ClisClis
Beitrag von ClisClis »
interessante konstruktion..
was die bullen sagen würden?
ich denke: keine pedale^^^und n super rennsatze mit riesen nos flasche... haha
